Which 1.8 dx k jet coil Is best
i need a coil for a kjet 1.8 dx engine code, what is the best to get?
genuine bosch is all you need.
Brill thanks. I have a cheap shiny one on At the moment which I think is why I have no spark, do you have a part number so I can get the right one
just pop into your local gsf branch, they should be able to sell you the right coil :)
note you may need to change the dizzy cap, rotor arm and leads to match the coil if its been messed about with in the past. you have 2 styles early which has like a set of wings on the lead ends that contact the outside of the dizzy/coil hole. then the late style which have a pin inside the dizzy/coil hole and a smaller hole with clip on the lead end that pops onto it
