Rear drum brakes don't workhttp://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif
(In Topic #198202)
brake force regulator and still they don't work . The front disc brake work fine. I've got good fluid flow to the rear but just don't work. I've been advised to convert them to disc. So if anybody can point me in the right direction, it would be much appreciated.
Not sure about %ages but the vast majority of braking effort is done by the front.
Use the pointy screw driver thru a bolt hole trick to make sure the (non-)self-adjuster is pulled right down to take up all the slack.
Adjust pedal rod and bulkhead rods (what a wonk design) to take up wear and slack.
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
Audi A6 3.0 tdi Avant Quattro Le Mans 305bhp
Did they work fine before you changed the parts? Could it be that they just need 'bedding in' a bit?
Having replaced the parts you have you need to check the rear brakes are adjusted correctly (should auto adjust but the adjusters are not very good). Then check the handbrake adjustment is correct.
The Red Rocket! My Mk1 Tdi Build.....
My VAG family:
1982 Mk1, PD130 Tdi, 6 speed, ongoing project, to be my daily driver (one day)!
1983 Mk1, 1.8 Gti, stripped out, ongoing project, track car only.
1990 Mk1 Cabrio, 1.8 8v Turbo, G60 ECU, long term project (17 years so far)!
2008 T5 LWB, 1.9 Tdi, to be converted to camper when I've finished using it as a van!
1999 Audi A4 Avant Quattro, 2.5 Tdi, currently off the road, more work required.
2010 Tiguan R-Line, daily driver.
My VAG family:
Like a jigsaw, eventually I will get the big picture
Good luck..Andy
