Mk1 G60 Conversion
Hi. Ive just bought a full G60 conversion from a MK2 Golf. It has been advertised as ready to bolt straight into another MK2. how will this wiring loom match up when trying to fit it to my MK1 GTI. Is it the same, similar or totally different?
Any ideas
Graeme
Morning, I think they're pretty similar tbh but you need the wise words and advise from our resident vw guru. Come in rubjonny :)
the main ecu section splits from the fusebox run on a factyory G60, so if its been kept the same that will drop in. just a case of the fusebox part will need modification. the fusebox in a RHD mk2 is on the opposite side of the car so the lengths are all too long, plus a 90spec mk2 uses a different fuebox so it will need splicing
