fuel pump for a 20v conversion
(In Topic #188619)
so mine obviously doesnt have all the gti fuel tank and set up,
now ive bought a new gti fuel tank, is it worth me buying a second hand gti fuel pump set up or would people suggest a better route
ie do i need an accumulator / dont i ,. what aftermarket fuel pump would be best to use
whats peoples opinions and advice on the matter
cheers in advance
neil
or you could just use a lift pump and go for a bosch 044 pump
Old dubs never die, they just get lower
are you running a swirl pot smudge ?
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2%2Ffuel-tank-cleaning_3
if its a diesel one it just has a tin pot spot welded in which is an inferior design and isnt good enough for a petrol car. so i would say get a lifter pump and external swirl pot, and if possible send the tank back as it isnt a gti tank as advertised! the lifter pump will fit a carb tank just fine
the accumulator isnt required its there on the kjet system to smooth out fuel flow to the metering head, this job is done by the fuel rail on an EFI car
ive just secured a full gti fuel pump set up from brad on here,
so what do you suggest now jonny, still send the tank back, and if so whats my route now , cheers mate
Then I would go for the later cab/rocco/g40 shape polo lifter pump and swirl pot route as I've seen a fair few people suffer from fuel starvation with the diesel tank
i havnt had a real good look over it but from what i remember when putting it in the outhouse is where the paint had come off it it looked galv ? ill have to have a look
if its in good nick ill nip the new tank back , btw i sent you a pm on edition ref wiring mate
neil
Jon`s Dad
