Swapping a vacuum pipe
I need to swap over a few vacuum pipes due to a valve being potentially faulty.
How is the pipe removed from the servo? Is it just pulled out or is there a different method?
Ta
Man power pull it out
yep, pull it or pry a flat blade between the servo and hose to pry it off that way  :cool:
Cheers lads. I didn't want to just start tugging it.. Only to break it!!  :o
Bit of grease, copper slip or the likes to help it back in  ;)
Not much, just saves you pushing it and creasing it as I learnt haha.
