Fuel metering problem
(In Topic #184776)
Flat ,wont tick over, wont rev
I'll start from the beginning.
The car has been sat for 19 years , when trying to start it, it wouldn't go . Fuel was being dumped into the bores as if on full throttle, so I have changed the metering head over and got it to run (kind of).
It wont tick over, really flat and wont pick up. Pops and bangs a bit too, just like it has been extremely retarded on the ignition timing . If I unclip the air box and lift the flap slightly with my finger it runs sweet as a nut. Also if I push up on the flap / plunger in time with opening the throttle I revs free as a bird .
It seems as if there is to much pressure for the vacuum to lift the flap by itself.
Do I try and play with the mixture screw?
Any suggestions ????
Many thanks
Jase
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=25972
ignition timing is done at idle with dizzy vac line disconnected and plugged, for the idle and co thats just done at normal idle
in particular look at the flap to ensure its central, clean and height is correct
I will have a look of the position of the air flap next as I'm convinced the problem lies there. Won't be until the week end though.
Will let you know how I get on.
Cheers fella
Jase
