Accellaration question
(In Topic #188046)
Misfiring going up hills
Anyways my car is a MK1 Golf Cabby 1.6 GL 1984 with a Pierburg Carb and K and N air filter. I have just had the car MOT'd and changed the gearbox oil, Engine oil and filter, fuel filter, spark plugs,coolant flush and change and had the timing done at the garage. I am also using super unleaded petrol.
The car is driving really nice apart from an issue I have when I am pressing the gas peddle quite hard. When I do this the engine misfires. It is not as bad when I press the gas pedal more slowly. It also happens when I go up a hill. The distributer terminals are all good and so is the rotary arm,although I did not change it. The ignition leads look like the performance type ones that came with the car. Could these be at fault? I read on the internet you can spray soapy water on them to see for any leaks.This seams to happen when the engine is hot.
All help very much appreciated!
give the carb a wobble while its running, if idle changes the flange underneath has probably split
rubjonny said
for leads do this at night and spray a mist of water over, any arcing will show up much clearer
Just sprayed the leads and there is no arcing. I also gave the carb a wobble and idle stays the same. I havent changed the sparks ( thought I had). The parks all looked in good condition though but are single prong. I should change them really. Do you think that will make a difference? I did notice after setting the gaps on the sparks yesterday the car seemed to run better.All in all very happy with the way it runs. Very good pick up and good throttle response. Just want to get it as good as I can.
http://www.vwspares.co.uk/g1electrical.php
looks liek the 1.6 carb ones on there are tripples so bonus
http://www.carparts4less.co.uk/cp4l/c/Volkswagen_Golf_1.6_1984/p/car-parts/car-service-parts/regular-service/spark-plugs/?408771280&1&bfd816b56ea94e27d2c53616fa901aa38022c155&000301
If you are buying new spark plugs best to fit some new HT leads they can make alot of differance in starting and running, just make sure you order the right type depending on what you have already, they will be a pin in the dissy cap where the HT lead fits or no pin. New dissy cap and rotor arm would also be on my shopping list as they don't last forever.
Last edit: by mark1gls
just buy oem equivalent quality parts and you're sorted. no need to spend a fortune on uprated coils, leads and mega plugs engine doesnt care what coil, plugs, leads and cap/arm you have fitted. its just wants a nice strong spark at the right time
not saying that bosch supers or whatever are bad, just dont spend a fortune on em, linky above is not bad price really they can be really pricey from some places
just dont tip the carb upside down or anything else all the petrol will come out
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=14917
